Feb 13, 2017 #1 K KBR27 Newbie level 1 Joined Feb 7, 2017 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 7 what sampling frequency is used to calculate the frequency usimg fft what sampling frequency is used to calculate the frequency usimg fft,either fft sampling frequency or input signal sampling frequency.
Feb 13, 2017 #2 KlausST Advanced Member level 7 Joined Apr 17, 2014 Messages 25,161 Helped 4,868 Reputation 9,757 Reaction score 5,537 Trophy points 1,393 Activity points 168,360 Re: what sampling frequency is used to calculate the frequency usimg fft Hi, you may run an FFT with any (constant) sampling frequency. It depends on your application? either fft sampling frequency or input signal sampling frequency. Click to expand... Usually there is only one sampling frequency. The ADC sampling frequency is the FFT input (sampling) frequency. Maybe you have a special case. Then you should tell us. Klaus
