which pins are uart pins in pic24fj128gb106
engineer khan
Member level 3
i have pic24fj128gb106 microcontroller and i need to use its uart pins but i dont find it ,the pin diagram is shown
Here's a big RTFM for you: There are no dedicated UART pins. It took me 1 minute to find your answer; now you try. It's fun and easy!!
I sought too much but i didnt find uart pins in the above controller
please someone is there to help me thanks
From the data sheet - Register 17.1 (page 202):
Note 1: If UARTEN = 1, the peripheral inputs and outputs must be configured to an available RPn pin. See
Section 10.4 “Peripheral Pin Select” for more information.
You have to assign the TX and RX pins of the selected UART each to one remappable pin. You choose the pins, they can be any of the remappable ones.
Brian.
i didnt find uart pins in pin diagram what to do please
I would suggest reading classes or an alternative profession may be the best way forward.
Brian.
Reactions: barry
    barry
the image attached shows the schematic of a PCB using a PIC24FJ256GB110
the PC serial is connected to pins 49 (RP10) and 50 (RP17)
the code to set up the UART pins is
     #include <pps.h>
    iPPSOutput(OUT_PIN_PPS_RP17, OUT_FN_PPS_U2TX);      // TXD
    iPPSInput (IN_FN_PPS_U2RX, IN_PIN_PPS_RP10);       // RXD
uart pin designation in pic24fjxxxgb106
I tried my best but not found uart pins such as Rx Tx pins in pic24fjxxxgb106 microcontroller,,,i dont know their representation in the pin diagram please please help me finding uart pins in pic24fj series,what is their representation in pin diagram???
Re: uart pin designation in pic24fjxxxgb106
hi,
Look at page #140 of the datasheet, it requires that you define the UART using the Peripheral pin selection register.
Also Table 4-10 on pages #50 & #57.
E
Note that horace1's example code uses UART2, you need to change U2TX and U2RX to UxTX and UxRX where 'x' is the UART number you are using.
Brian.
'There is none so blind as he who will not see.'
There is none so deaf as he who will not listen.
attached is the schematic for a PIC24FJ64GB004 (similar device to a pic24fj128gb106)
the PC serial is connected to pins 6 (RP2) and 7 (RP3)
the code to map the pins to UART2 is (accessing the PPS registers directly not using pps.h functions)
    _RP3R = 5;					// for UART2 Rx and Tx
    _U2RXR = 2;
