Apr 12, 2006 #1 V vfurlan Full Member level 2 Joined Mar 27, 2006 Messages 133 Helped 10 Reputation 20 Reaction score 2 Trophy points 1,298 Location Slovenia Activity points 2,185 Vivaldi antenna gain Hi! Which are parameters that affects gain of the Vivaldi antenna? Is in length, taper hight, or something else? What is max gain I can obtain from Vivaldi antenna at cca. 1.8 Ghz? Thanks in advance
Jul 1, 2007 #2 H habeebhabz Junior Member level 1 Joined Apr 13, 2007 Messages 17 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,389 Re: Vivaldi antenna gain Hi, Check the paper " A parameter study of Stripline-Fed vivaldi Notch Antenna Arrays" by Joon Shin and Schaubert. Just google out, you will get it. Habeeb.
Jul 2, 2007 #3 V vfone Advanced Member level 6 Joined Oct 10, 2001 Messages 5,709 Helped 1,616 Reputation 3,237 Reaction score 1,248 Trophy points 1,393 Activity points 36,263 Re: Vivaldi antenna gain Theoretically the gain could be up to 10dBi but a normal peak gain value is around 5dBi.
