which of the follow circuits can generate glitch free gated_
littlefield
Junior Member level 3
which of the follow circuits can generate glitch free gated_clk?
A.always@(posedge clk) gated <=en;
assign gated_clk=gated&~clk;
B.always@(negedge clk) gated <=en;
C.always@(posedge clk) gated <=en;
assign gated_clk=gated|~clk;
D.always@(negedge clk) gated <=en;
this is an interview question, but I don't think any of above answer is corect, Am I wrong?
Re: which of the follow circuits can generate glitch free ga
Hi littlefield,
I think B answer is correct.
This will make sure 'en' always changes in inactive duration of the clock :D
____------____------____------____------____clk
------____------____------____------____------~clk
------------------------_____________________en
-----____------____X____________________gate_clk
if choose B
I think it will have the glitch at the point X,
at this time, (~clk) change from low to high, en change from high to low.
if we do RTL simulation, it haven't glitch
but we do the post-layout simulation, it probably have glitch
A is the answert
___________________-----------------------en
___________________x___------____------gate_clk
if choose A
at this time, (~clk) change from high to low, en change from low to high.
Your interview question must have a precondition.
en is synchronous with clk and have a little phase shift.
If no this precondition, this design must have clock domain crossing mechanism.
