T
treez
Hello,
We need to test our 165W, switch mode LED driver (as well as our future led drivers) and do not wish to just use a resistive load of the same power and voltage level as the led load. The led driver uses a negative feedback loop to regulate the led current. (Max LED loading = 46.4V at 3.52A)
If we just used a resistive load, then we would not be able to truly investigate the propensity of the led driver to go unstable. Thus we need a dummy led load which has a low dynamic impedance and a fast frequency response, -in other words, it must mimick the led load’s dynamic properties.
Do you believe that a switch mode led driver, as described, would be more likely to go unstable when supplying LEDs (or a LED simulator) than if supplying a resistive load?
We believe that a led load (compared to a resistive load) has a higher frequency RC output pole, and thus there tends to be more danger of going unstable…Do you agree?
Attached is a diagram if the led driver driving a led load, and also two different types of led load simulators….which led load simulator do you believe would be best at mimicking the leds?
(LTspice simulation of led load simulators also attached)
