rrlamichhane
Newbie level 3
This circuit is intended to 'short circuit' the 'AC power mains' while there is voltage on the AC line and 'open circuit' the inverter line' at that time. If the 'main line' goes out then it will 'short circuit' the 'inverter line' to destination and 'open circuit' the AC main line. The 24V DC is generated from 'main ac line' so it can be used to control which line get's 'short circuited' and which one gets 'open circuited'.
I know, it's really easy using the Mechanical Relay, but I want to use a 'Triac' and also can you guyz tell me what are the advantages of using Triac over Relay on this purpose? And also which one is more durable?
