Apr 5, 2007 #1 K kunal1514 Full Member level 1 Joined Dec 13, 2006 Messages 98 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 2,027 Hi All,, Can any body tell me that which one is better to code A logic which works on clock or a logic which is combinational where as i can write combinational logic using clock also. Regard's Kunal Mishra
Apr 5, 2007 #2 D dk614nd Advanced Member level 4 Joined Aug 8, 2006 Messages 106 Helped 46 Reputation 92 Reaction score 17 Trophy points 1,298 Activity points 1,997 Re: Design depends on your application
Apr 5, 2007 #3 U uditkumar1983 Advanced Member level 4 Joined Dec 3, 2006 Messages 107 Helped 6 Reputation 12 Reaction score 2 Trophy points 1,298 Location India Activity points 2,019 Design Its depend on ur application only ,If u want output of this logic fastly than go fo combinational and if there is any problem related with glitch or demand for high frequency than go for sequential logic..
Apr 6, 2007 #4 L learnbydo Junior Member level 2 Joined Jun 18, 2005 Messages 22 Helped 1 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,408 Design register your output if there is no need to optimize. this will make the circuit easy to integer with other part of design
Apr 9, 2007 #5 S sumit_techkgp Full Member level 2 Joined Apr 1, 2007 Messages 133 Helped 8 Reputation 16 Reaction score 5 Trophy points 1,298 Activity points 1,866 Design It depends on what you want!!!!. The code will be written after visualize it (rather design it), you will not design it after writing the code.
