Which FPGA is better: XILINX or ALTERA?
anoop12
Member level 5
I would like to know which FPGA is better among XILINX and ALTERA?
regards
Re: Xilinx or @ltera
anoop12 said:
I would like to know which FPGA is better among XILINX and @ltera?
regards
One or the other isn't better or worse.
You need to look closely at your application, and decide what features are most important, whether it be power usage, low-cost, etc. Then look at the available FPGA's in your price bracket and see which ones suit your needs most closely.
Re: Xilinx or altera
Hi.
We cannot say Xilinx or Altera is better. Its all depend on your design req, pocket size, the tools ur already having etc.
Take a look at different FPGA from both these vendors.
Hope it helps
Thanx
Xilinx or @ltera
It depends your requirement. I prefer Xilinx. It is my personal opinion.
Xilinx or @ltera
Yes, Xilinx flow is more like ASIC flow --- so it's used widely in ASIC emulation.
Altera is not such flexible but can meet your req anyway...
Xilinx or @ltera
xilinx is more controllable,
altera is more easier for beginner
Xilinx or @ltera
I prefer Xilinx cos I use it more often.
If you were from Synopsys camp, then Altera may look appealing due to the constraints in Altera is the same as Design Compiler. However in Xilinx you need to twist your mind when constraining setup/hold time delay.
Xilinx or @ltera
I think Xilink befor use FPGA and Altela befor use CPLD
Xilinx or @ltera
They are same.
Make sure you have good support from vendor you selected, also look at lattice as well
Xilinx or @ltera
The same but CAD tools for xilinxs are better.
I think it depends on which supports you can get from the vendor are more.
As I experience, Xilinx seems that it has more resources about their development kit. (ex. design examples, application notes, etc...)
For Altera, I will recommend they can improve the resources about their development kit.
It just my opinions...
B.R.
Xilinx or @ltera
I do prefer Xilinx 'coz of its resources. But I think Altera iz gud and morever they had opened an R&D in my country, Vietnam :D Now I'm doing both on Altera's and Xilinx'
Both Altera & Xilinx have comparable technology & parts in terms of FPGA & CPLDs. The issue is usually the IP & the tools: Xilinx ISE vs Altera Quartus.
Xilinx or @ltera
EU folk seem to favor Xilinx while US prefer Altera - can't explain it so just sharing an observation. Neither is better nor worse. I think most engineers will favor the IDE and from there the actual product. I like Quartus better than ISE but that's just me, plus my geographic opinion could have something to do with that seleciton too :)
