which differential amplifier configuraion should i choose?
samuel
Full Member level 3
Full Member level 3
world
Now, I want to design differential amplifier tused to substract the two signals from correlated double sample(CDS).
input signal range : 3~3.9, that is to Vin+ ≤3.9 and Vin-≥3.
powe supply:5V
frequencey:≥5M
load: capacitance:15p
anyone can give me some advice?
thanks.
samuel.
what's supply voltage? Signal frequency? Power consumption? Driving capability?
N-input-pair better for high input cm level,
and your working freq is high, also you need only drive cap loads, so 1-stage folded-cascode is good for your design.
Take care to your GBW and SR.
Re: which differential amplifier configuraion should i choos
N-input pair has better matching and more gain. But why better for high input level? Comment pls. Using p-input you get more slewing and less noise
LaTeX Commands Quick-Menu:
