eki27
Newbie level 3
Hello,
Could you please help me to find the reference of a product able to do the folowing job:
Supervise any voltage change (positive or negative) of at least 10mV on an analog circuit (which can take a variable value from 0V to 1,2V) and produce an output pulse (ideally a 0V for +-300 mS) for each detected changes?
I will use the output of the component to wake another µP which will convert the analog value to numeric...
The input of the component will be connected in parallel with the input of the another µP, the component should therefore been high impedance input.
Thank you in advance for your suggestions and have a nice evening!
Eki
Eki
