i have made a projct usin at at89c51 and have developed assembly language for it. however i dont know how to compile it and burn the prog to its flash . how to go about?
if you are using the 89c51 it can't be programmed by ISP you will need a programmer. or the better solution is to use 89s52 which is the exact same but can be programmed using ISP.
