Where to change the skew if it doesn't match after optimization?
mujju433
Full Member level 3
Full Member level 3
After doing optimization also if my skew doesn't meet then where will u go and change the skew???????????????
Re: skew
then you would have to take to the solution of pipelining your circuitry.....
skew
change your design archirechture
Re: skew
If you are working with ISE just check the clock is using Global clock buffer or ordinary buffer. If it uses ordinary buffer the clock will have large skew.
Regards,
Kanags
skew
Xilinks ISE (Integrated Software Envirement) is a software for Xilinks FPGA simulation, P&R & synthesis.
Re: skew
If you mean clock-skew, you can refer the answer in below.
Clock skew is difference from highest insertion delay and lowest insertion delay of clock tree.
You should build the clock-tree better to increasing clock-skew. Don't separate the clock tree if possible! Or you can search CTS distributtion from this forum for your details.
thanks!
skew
you can always manually adjust the skew.
skew
By definition skew is the difference in insertion delay between any registers under a specified clock tree. If you are not meeting skew then your cts tool is crap and you will need to manually fix the skew by adding or deleting buffers. Either way it is not something you want to do manually.
Re: skew
Possible solutions :
1. Increase insertion delay and run cts again
2. Start with a different clock tree topology (as the pervious topology might have had a local minima).
Re: skew
if the skew is more and not fixable by cts then you need to change clock tree structure
skew
or may be you can use the skew to retime your datapath.
skew
You should balance skew/insertion delay and clock buffer/inverter types in oder to get reasonable clock tree,and this will useful for later optdesign
