Where the ground pin of the scope is connected to in Proteus?
epilot
Member level 2
Hi guys,
Can you guys please let me know where the ground pin of the scope is connected to in Proteus software?
For each channel we just accesses to one pin of the scope not to ground of it, So where the ground is naturally connected to and how to change it if needed?
Thanks
Re: Ground scope Proteus
Hi
When you run the simulation you can set channel B to GND, and have A display A+B, connect ground to channel B.
Bob.
Reactions: epilot
    epilot
Hi
Bob.
Thanks but If I wanted the reference point to be other where rather then the ground?
I think the best solution would be to use an analog graph, add one probe in each of the two nodes and then add them in the graph (right click -> add traces) as probe P1 and probe P2 and in the expression field use P1-P2, this will show the voltage of the probe selected in P1 with reference to P2.
Alex
Reactions: epilot
    epilot
