Where is the pwell in the deep nwell
shanmei
Advanced Member level 1
USA
Fig.1 is the deep nwell nmos layout generated from the schematic. The out box line shows that they are two layers overlapped, dnw and wellbody.
In Fig.2, I add a ptap to the bulk, short S node and bulk. I add a ntap ring inside the deep well box, which makes the nwell connected to vdd.
Questions:
1. Is it correct that I add the ntap ring inside the deep nwell to connected nwell with vdd as shown in the Fig.2?
2. It seem that the bulk(pwell) in Fig.2 can't be related to pwell in Fig.4. Bulk(pwell) in Fig.2 is just a tiny part which is around source node. While the pwell in Fig.4 are all round the source and drain node. Is Fig.2 layout is coresponded that the Fig.4 layout?
3. If I add the bulk around the transistor in Fig.4, and add ptap to the bulk, does the pwell from Fig.4 now can coresponed to that from Fig.4?
4. If I use the bulk(pwell) drawing method in Fig.2, is it correct?
Thanks.
Questions:
Yes.
No.
3. If I add the bulk around the transistor in Fig.4, and add ptap to the bulk, does the pwell from Fig.4 now can coresponed to that from Fig.3?
Yes.
Fig.2: no ; Fig.3: yes (same question as #3).
Now I understand that we should add the ptap around the nmos devices for analog circuit layout. Adding ntap around the pmos devices as well. Thanks, Erikl.
Yes,you must have concept that mos devices are 4 terminal devices! Sometimes may exsit 5 terminal!
