david90
Advanced Member level 1
The type of SMD LED that I'm looking for is the reverse mount kind. I'm not sure if that is what they call it. Basically the LED top is facing into the PCB when mounted. A hole is drilled between the LED mounting PADs so that you can see the light when looking at the LED from the other side of the PCB.
I've tried digikey but I couldn't find any.
