A cheaper alternative to Arlon and Emerson&Cuming products is to buy the very common panels of expanded (or extruded) polistyrene.
They are very common material used for housing.
I tryed the Basf 3035® up to 47 GHz , εr≈1.05 and tanδ so small to be near the noise of meter.
Thanks for all your information. But I am still curious about whether the materials you guys mentioned above is not for prototype design?
Since I am looking for the form in order to support the PIFA and other antenna prototypes' copper foil, so I need the foam that is easy to cut by hand and sticked to PCB. Also, the price should be as low as possible.....
