Register Log in
where can I get RHEL 3 for IC5141??
8k-rom
Junior Member level 2
bash: icfb: command not found
When i install ic5141 in my RH7.2 completely,and cannot find .cshrc or .tcshrc file....There are only .bash_profile in my root directory.
what should I do ??Modify the .bash_profile ??
who can help me ?? or give me some tips...
PS: some people said that RHEL 3 or 4 is good for IC5141. where can i download
them.???
thanks ...
Added after 14 minutes:
When I key in the terminal :icfb &
then it told me that :command not found.
what's wrong?
adsl
Member level 4
where to get rhel3
.bash_profile is used when your default shell is BASH while .tcsh/.csh is for tcsh/csh. It does not matter which shell you're using but you need to set PATH correctly.
8k-rom
icfb command not found
I modify the .bash_profile like this
export CDSDIR=/root/cadenceic5
export CDS_ROOT=/root/cadenceic5
export CDS_INST_DIR=/root/cadenceic5
export CDS_INSTALL__DIR=/root/cadenceic5/tools.lnx86/dfII
export LM_LICENSE_FILE=/root/cadenceic5/share/license/license.dat
export CDS_LIC_FILE=5280@10.13.29.13
export CDS_Netlisting_Mode=Analog
but still can not work
when key in "icfb &" ...
it tells me icfb: not found
sigh~!!
adsl
Member level 4
ic5141 bash_profile
The most important thing is to incorporate the binary path into the PATH env variable:
export PATH=<path-to-icfb>:$PATH
for $SHELL being able to find icfb and the other variables become effective then.
8k-rom
$ bash: icfb: command not found
thanks ...adsl
After modified, and key in the teminal :icfb &
It told me :
*ERROR*:Failed to find either 24-bit TrueColor or 8-bit PseudoCOlor Visual
What does it mean? and how should I do??
adsl
Member level 4
rhel3 download
That's too bad. It means that you can't using true color (24-bit) mode. Try to set your X window to 8-bit mode by modifying XFree86config, XF86Config, or Xorg.conf. It is in /etc/X11/.
8k-rom
rhel .bash_profile
Thaks a lot!
When I change a monitor ,I found I can star IC51 now !
But ,there is still something wrong .
When the CIW display on the destop,the background color of the destop become so terrible...and in the end of the CIW,there are some warnning:
Warning:Cannot allcate colormap entry for default background
Warning:Cannot allcate colormap entry for "#e0e0e0"
and so on~!!
BTW:this computer(bought in 2000) is an old machine,maybe the memory value of the display card is not enough....
maybe....
Added after 23 minutes:
okay~~!!!
i have conquered it now !!!
thanks a lot !! adsl
Toggle Sidebar
Design Fast
