Where can I find 16f877 programmer circuit?
mscorpion
Newbie level 3
Newbie level 3
Turkiye
where can i find p16f877 programmer circuit?
You said that you want a programmer for PIC16F877. It's really a programmer that you want or a bootloader?
For programmer check this sites:
www.ic-prog.com (ICProg) www.lancos.com (PonyProg) www.propic2.com (ProPic2) www.melabs.com (EPIC)
For bootloader check:
www.dontronics.com/rfarmer.html www.workingtex.com/htpic/PIC_bootloader.htm
For last check www.bubblesoftonline.com it has some programmers and bootloader.
I use IcProg for programming my PIC's, never the less correct programming of the µC depends of the capability of the serial port to supply enough current. If you want to program OPT µC i recommend you to use EPIC (parallel port) it uses a external supply but it 100% reliable.
There are many more programmer and bootloader in the net, if you do a search will find other but i believe that the above are the most common.
I hope this post answer your question.
i looked all of them but i didnt find concrete something...
