T
treez
Electric car batteries are very poor. If you hook up to a 50kW charger, then you will only charge at 50kW if you are completely flat…as soon as the battery voltage picks up (which doesn’t take long), the charge rate goes down to a few Kw ‘s at best. (it must go down otherwise the battery voltage soars too high) So when will this problem be solved?
