achilles09
Newbie level 6
in some papers ,they concerns the phase margin when gain is 0 dB, but when when the loopgain is not come to 0, the phase margin is not enough, is this not important?
achilles09 said:in some papers ,they concerns the phase margin when gain is 0 dB, but when when the loopgain is not come to 0, the phase margin is not enough, is this not important?
LvW said:Comment to Keith' reply: If the loop gain never is higher than 0 dB the whole feedback makes no sense. Or did I misunderstand something?
LvW
keith1200rs said:.............
When loop gain is >0dB therefore, the phase margin will be higher (unless it has a very peculiar phase response). So the only time where phase margin could be worse is at higher frequencies than the 0dB loop gain. That is what I was trying to say
Keith.
keith1200rs said:What would you call the phase "margin" at 20dB then?
The original post was "but when when the loopgain is not come to 0, the phase margin is not enough" so I was replying to that question.
Keith.
checkmate said:I normally regard the phase margin as the minimum phase difference from -180 degrees while gain is above 0dB. This will take care of cases whereby the magnitude response crosses the 0dB line multiple times, and when "bumps" are found in the phase response. Such scenarios are possible when LHP zeroes are used for compensation.
