engrbabarmansoor said:why do we generally use 50% duty cycle i.e 50% high and %50%low?
Can we use other values?
Wht will be the effect of using other %age
knack said:engrbabarmansoor said:why do we generally use 50% duty cycle i.e 50% high and %50%low?
For application like a PLL XOR phase detector, it will not work correctly unless you use a 50% duty cycle inputs..
Cheers,
-- Knack
DZC said:engrbabarmansoor said:why do we generally use 50% duty cycle i.e 50% high and %50%low?
I have the similar question: In Which Situations should We Apply A 50% Duty Cycle Clock?
ch1k0 said:50% duty cycle square wave has no even harmonics.. so what? not that important (if true..).
ch1k0 said:could you explain why periodic signal 50% duty cycle show no second harmonic, and periodic 75% duty cycle has?
