When soldering small SMT resistors, capacitors and transistors, I can't get them FLAT on the PCB
I have to use the Hot Air gun to melt the solder to make the component FLAT on the PCB
If I use the soldering iron to solder SMT components, The SMT components have a Slant or they are lifted on one side
How do you place and push down or keep the component in place while soldering?
Using tweezers the small SMT part will fly away or it keeps slipping out of the tweezers arms and falling out and it's really had to place it and solder , tack in the SMT component
When I use the Hot Air gun it will heat up both sides of the SMT resistor or capacitor and it will melt the pads flat and I can remove and place it better
But most of my SMT solders using a soldering iron on Slanted or they look like the are lifted on one side? How can I get it flat?
