When I plot an output on an terminal A and there is an erorr: A is not a kept output
nga_nguyen
Newbie level 6
Newbie level 6
When I plot an output on an terminal A and there is an eror that "A is not a kept output!" What does this mean?
Thanks
Re: eror in Cadence!
Hey Its like Cadence Spectre if you are using ....
it stores all the node voltages by default...if you want to measure the output current you need to select it through
Outputs-->to be plotted OR Outputs -->to be saved option in Analog Design Environment wondow.
Then it should work..try it...
