when i am trying to simulate in Proteus it comes with error
akhilpaulv
Full Member level 2
Full Member level 2
Thrissur, India
here is the program(programed in mikroc pro for 8051 and microcontroller is at89s51)
sbit LCD_RS at P0_0_bit;
sbit LCD_EN at P0_1_bit;
sbit LCD_D4 at P2_4_bit;
sbit LCD_D5 at P2_5_bit;
sbit LCD_D6 at P2_6_bit;
sbit LCD_D7 at P2_7_bit;
sbit h at P3_6_bit;
sbit s at P3_5_bit;
void main()
int i,a[25],p,b,w,g,t;
char txt1[] = "push button";
char txt2[] = "got it";
char txt3[] = "no";
char txt4[] = "yes";
char txt5[] = "searching";
char txt8[] = "ready to begin";
P1=0xFF;
h=1;
s=1;
P3=00;
P1=00;
h=0;
s=0;
 Lcd_Init();                        // Initialize Lcd
  Lcd_Cmd(_LCD_CLEAR);               // Clear display
  Lcd_Cmd(_LCD_CURSOR_OFF);          // Cursor off
  Lcd_Out(1,1,txt1);                 // Write text in first row
while(s)
  Lcd_Out(1,1,txt5);
  for(g=0;g<25;i++)
 for(i=0;i<2;i++)
   P3=0x01; //0001
   delay_ms(10);
   P3=0x04; //0100
   delay_ms(10);
   P3=0x02; //0010
   delay_ms(10);
   P3=0x08; //1000
   delay_ms(10);
 a[i]=P2;
 for(i=0;i<25;i++)
 if(t=1)
 a[w]=0;
if(a[i]>p)
b=i;
p=a[i];
 for(i=0;i<b;i++)
 for(g=0;g<2;g++)
   P3=0x01; //0001
   delay_ms(10);
   P3=0x04; //0100
   delay_ms(10);
   P3=0x02; //0010
   delay_ms(10);
   P3=0x08; //1000
   delay_ms(10);
  Lcd_Out(1,1,txt2);
  switch(h)
      case 1 :
  w=b;
  t=1;
  case 0 :
  Lcd_Out(1,1,txt8);
Your link is not working. What error are you getting in Proteus? Pins used for LCD are not initialized as output pins. P0 needs pull up resistors of 10k.
