what's wrong with this code?(microC & proteus)
mailus
Full Member level 4
Full Member level 4
sbit led1 at rb0_bit;
sbit led2 at rb1_bit;
sbit sw at ra0_bit;
sbit sw2 at ra1_bit;
void main()
adcon1=0x07;
cmcon=0x07;
trisa=0xff;
trisb=0x00;
portb=0x00;
do{
 if(Button(&porta,0,10,1))
 led2=1;
 led1=1;
 delay_ms(10);
 }while(sw=~sw);
 if(button(&porta,1,10,1))
 led1=0;
 led2=0;
 }while(sw2=~sw2);
 delay_ms(10);
 }while(1);
when i use this code output assign function did not work correctly;
it sets the last assigned values only;
for example:
 led2=1;
 led1=1;
 delay_ms(10);
 }while(sw=~sw);
after executing this code output assigned only for led1 only;
here led2 is missed in this step;
please clarify my problem..............
First:
while(sw=~sw); //??? sw is an input, so not writable
//correctly, as jayanth wrote:
while (sw == ~sw );
But this is meaningless (generally), can be omit (1 is never equal to 0)
2nd:
Your problem is a tipical RMW issue. Try this:
 if( Button(&porta,0,10,1) )
   led2 = 1;
   /*  led1 = 1;   moved after the delay */
   delay_ms(10);
   led1 = 1;
// while ( sw == ~sw );
And look at the MikroC help, what says about the "Read Modify Write Problem"
