what's wrong with the virturso@schematic
xdyrick
Junior Member level 1
schbindkeys.il location
this the graph that i open the virturso schematic editor,but i cann't use any
hotkey and you can see in the graph the icon is not complete
what's wrong ?
what's wrong with the virturso(at)schematic
You don't have license...
There is a problem with the local directory which has the cinit file.
Hie,
This usually happen when you don't have license.
Meanwhile they can happen also if you are trying open a cell that are already in use by some one else.
amendes
I can't run the f hotkeys. all other features are running.
without licesen, could they still open cadence?
Yes! without license you can open and see both scematic and layout, but you cannot make any change of it.
u can check the following file it contains every function and the corresponding hotkey so u can know where the problem is
<installed dir>/tools/dfII/samples/local/schbindkeys.il or <installed dir>/tools/dfII/samples/local/lebindkeys.il
