Whats wrong with my full wave bridge rectifier?
rabinsakha
whats wrong with my full wave bridge rectifier?
Re: Whats wrong with my full wave bridge rectifier
No DC input.
Connect GND to left of bridge.
Thank you for the reply. I am getting output of the rectifier by vout2-vout1 as shown in the equation. The thing is i am getting very low efficiency. Even impedance matching is not helping me to get higher efficiency.
It's not obvious what your meter is measuring. Volts or Amperes?
I believe you should connect a voltmeter across the capacitor and resistor.
I_PROBE device name suggests the latter.
How did you try impedance matching? Presently we see a large series inductor L1 that's probably dropping most of the input voltage.
I think it is natural.
Your load is floating, on the other hand, a drive is single-ended.
I tried impedance matching using smith chart utility. If L1 is dropping most of the voltage, should i avoid using inductor in matching. What are the ways i should try to increase efficiency?
Thankyou for the reply.
What can i try to increase the efficiency of this bridge rectifier?
Thank you for the reply. i tried impedance matching using smith chart utility. If L1 is dropping most of the voltage, should i avoid using inductor in matching. What are the ways i should try to increase efficiency?
Thank you for the reply,
i have removed the i probe and voltage measurement is done as vout= vout2-vout1 , from the pin voltages vout1 and vout2 as shown in the figure
How did you determine the rectifier input impedance?
i used the ADS tool Zin to calculate the real and imaginary part of input impedence
How did you calculate the efficiency ?
Have you considered the Power factor ?
Insufficient information.
Please let us know the approx frequency and then also approx magnitude.
Calculate the reactance of the inductor and capacitor at the typical frequency.
I do not see anything wrong with the full wave bridge rectifier. Once you get an idea of the expected value then we can compare with the observed value.
Is the diode rated for high frequency operation?
