vaka85
I have to amplify a very small 4 MHz sine signal (about -50 dBm) received from a loopstick antenna (but my problem is the same with a sine input given with a function generator).
Since I'm using a lt1364 (I'm waiting for a more wideband amplifier, now I have that LT and I'm using that one..) which has a gain-bandwidth of 70 MHz, I'm using two stages, each one with an amplification of about 10.
The problem is: if I test the two stages separately, everything is fine, but when I put them together the gain isn't 100 (about) but something around 30...
Could you tell me where I'm wrong? here is the schematic:
thank you very much
thank you very much
