jeffben
Newbie level 2
Hi everyone
I am using IBM cmos10lpe 65nm process. In some low frequency circuits, I need relatively large resistor (>500k) for the bias resistors. The sheet resistance of p+ poly resistor in this process is about 660 om/square.
I feel it is very easy to make a poly resistor of 500k or 600k, even 1M while not taking up too much area. However, someone told me that because the substrate is also p type. The current would also go through the substrate. Therefore the actual resistance should be the parallel result of poly resistor itself and the substrate resistance. is that true? If this is true, then I will never be able to make a large resistor, say 1M.
Can anyone kindly answer my question or tell me the substrate sheet resistance for this process. Thank you in advance!
Jeff [/b]
Jeff [/b]
