They will be equal only for a single-pole system ( or for a higher-order system that can be approximated by a single pole system, such as OTA's with enough Phase Margins ). This can easily be proved
Only equal if the second pole is far away enough from the first pole (dominant pole) where in this case you can approximate the systems as a single pole transfer function response
