what's the difference between them
tigerajs
Member level 3
Member level 3
"@posedge clk" and "@posedge clk;"
First is a condition, another is a statement.
A semicolon ! Kidding ............ :) . Let me put it is code snipet and tell you .
1.
@posedge clk
a = 0 ;
// here the value of a is assigned to 0 after the event of posedge of clk .
2.
@posedge clk;
a = 0;
// Here value of a =0 after the event posedge of clk.
1.
@posedge clk
a = 0 ;
2.
@posedge clk;
a = 0;
If you only contian a assignmets in one block, there's no difference for these two ways; however, if there are more than one block which will assign some values to a with these two methods, then the result may be different.
Thomson
