What's the difference between static and dynamic timing analysis?
diemilio
Full Member level 6
Framingham, MA
HELLO
Could someone please explain me what's the difference between static and dynamic timming analysis
thanks,
diemilio
Re: timming analysis
Static timing analysis pertains to calculating path delays without applying any test vectors. The dynamic analysis is related to gate level simulation after inserting delays for each gate this done after synthesis, this needs test vectors to analsys. The path delays varies with applied test vectors. This DTA takes more time compared to STA.
    diemilio
Hi can i know what is skew in digital? What is its effect?
Can anyone give a practical example about this?
thanks in advance!
skew is related to clock, this term comes when ever there is difference in arrival of clock at the two or more different syquential circuits in the design. This can be eleminated by using clock trees like H-tree or star n/w, the clock skew can also exists in between two different chips (have interdependent operations) which are sharing same clock signal. This can be eliminated using PLL's.
any coments plz free to ask.
timming analysis
Generally, static analysis is used to verify setup time violation, hold time violation, recovery and removal time violation, gate-clock timing check. and so on. Dynamic can also check the setup and hold, but it depends on vector stimulus, In my opinion, it is used to check the functional problem more often.
diemilio said:
HELLO
thanks,
diemilio
STA - Static Timing Analysis is a formal method to prove the timing correctness and DTA is a Dynamic/Simulation based technique. As of now, STA dominates but DTA is still used, say 95% STA and 5% DTA - but the exact % might vary. STA has the advantage of "completeness" as it is a formal approach, but has some issues such as:
The constraints may be wrong
Can't fully handle async clock domains
etc.
Infact in my company we are exploring STA to DTA linking via Assertions.
We cover this topic in detail in our CFV course, see: www.noveldv.com for more on the course.
HTh
Ajeetha, CVC
www.noveldv.com
can anybody just brief me about
how to perform DTA and STA?? with tools/software/process involved..
DTA can be performed using VCS,NCSIM,modelsim etc
synopsys Primetime is best for STA
timming analysis
in short, STA is by using timing analysis tool to check timing violations, particularly in the stage of synthesis;
DTA (first time to hear ) is by postlayout simulation with either simulator, and sdf backannotation, for such purpose, u usually need perform two runs: bestcase and worstcase.
