.print will print the value in text format for you, so you can checkout the text output format.
.probe enable you to store the simulation output in a special file that you can use a waveform viewer to view the signals. eg i9f you want to see volt at node v1, you will write
.probe v1
and then in your option, you add
.option probe
.probe v1
.option probe
if you use .options probe then you must add .probe *** in your sim file;the .options probe means only probe the special node in output file ,if don't special node then hspice will not probe any wave.
