walters
Advanced Member level 2
Why does a strobe circuit use a Diac and triac?
Why does a strobe circuit need a trigger transformer?
Whats the difference between a Flashlamp VS a +9 volt Lamp? besides the voltage how are they lighting differences , what does a flashlamp do different?
Strobe circuit theory:
1.) the trigger pulse is 4 kV
2.) Discharge durations for common flashlamps are in the microsecond
3.) xenon flash lamp
4.) pulse transformer or 4KV Trigger Transformer
5.) The stoboscope tube needs about 250-400V DC to operate
6.) triac which can handle at least 1A and 400V
7.) 150 uF 400V flash capacitor
8.) The flash rate is variable from zero to about 10 Hz
