ste2006
- Joined
- May 1, 2012
- Messages
- 118
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 1,298
- Activity points
- 2,226
I have a 4 layer board I am working on and it was perfect, In the design and testing stages though I had to cut a track as it was causing me issues. After cutting the track the board was fine but then when I pulled a battery pack out of it I started to get a 4 Ohm Short between the Ground and Vdd on the board. Whether I dug too deep cutting the track and shorted the power planes in the middle two layers I do not think so but possibly or whether it was just coincidence I am not sure.
I ended up drilling a clean 2mm hole through the whole board where I wanted to cut the track just to try to make sure that none of the inner layers were shorting but still a 4.1 Ohm short.
I would imagine if it was the inner layers shorting or a stray piece of copper I would be getting less than one ohm short but perhaps not??
Would 4 ohms sound like a bad component??
Any bright ideas for helping to track down this short?
I have board on a current limited supply and it keeps maxing out the DC-DC on board keeps screaming also as I assume its being overloaded by the short.
Any ideas would be brill as the boards only came back from the PCB house two days ago :sad:
Thanks,
Stephen
Thanks,
Stephen
