what value of resistor can i use to lit led in mains?
electrocraft
india
can i use led lit in mains? if what value do i apply !!!!!!!!!!!!!!!!!!! plez respond
Use V = IR.
R = V/I
Remember to take the LED Vf into consideration.
Assuming mains voltage = 220V, current through LED = 10mA, LED Vf = 1.4V and that you rectify and filter the AC using a capacitor, required resistance, R = [{(220 * √2) - 1.4}/(10/1000)] Ω = 30972.7 Ω = 30.9 kΩ. So, you can use 33kΩ and you'll get a current of [{{(220 * √2)-1.4}/(33000)} * 1000] mA = 9.39 mA
Hope this helps.
Tahmid.
you can also bypass the rectify so that the circuit will be simple. also you have to follow the step above by tahmid...
R = [(220 - 1.4)/(10/1000)] Ω = 21860 Ω = 21.9 kΩ. so approximately 22KΩ will be fine
now the second part will be the power dissipation of the resistor
from ohms law we get power = IV, where I = 10mA and V = 218
then it follows that P = (10/1000) X 218 = 2.2
so power dissipation will be 2.2 watts, hence your resistor should be able to withstand this power. though a 5 watt will be prefered.
hope this helps......
sequel
In that case you can not use a single resistor , you also have to add either a diode in series with the led or an anti-parallel diode across the led to protect it from reverse voltage.
Alex
Hello sequel,
No, you can not without a antiparallel diode, because the reverse voltage of LED is app. 5V. So your LED will exploded after the first halfwave of your AC voltage.
Regards
Rainer
just try it out....
then post the out come....sequel
though you get a better protection with the anti-paralleling diode. but the design above will still suffice
For lowering mains voltage to near leds voltage range, often is used parallel or serial link of resistor and capacitor. Capacitor lower voltage with his internal resistance, without heat, unlike if you use only resistor for that purpose. But current which pass through capacitor have reasonable limit for around 150mA.
See few examples:
LaTeX Commands Quick-Menu:
