You can also look at the minimum and maximum input voltage that your divider can handle before it stops dividing properly. In addition, you can also change the input rise/fall times to see what the maximum rise/fall time your divider can handle before it starts failing jitter spec or stops dividing properly. In relation to your jitter, you can simulate phase noise and get a print out of what your dominant noise sources will be in your divider design.
