lavitaebelle said:You can connect an NMOS in this fashion. Drain to drain of M6, source to the startup node(gate of M0). Connect the gate to a series of diode connected transistors down from vdd with a path to ground. What the whole set up does is that it pulls up gate node of M0, starts up a current in the whole path and when the circuit comes to stable current level, the start up NMOS will turn off. The diode connected transistors must be appropriately designed to switch off this start up NMOS.
Apart from that I am wondering how are u defining I1 and I2, as in what parameters define that.
srivatsan said:I would look at the Gray/Meyers and Johns/Martin books' based start up circuit.
