T
treez
Hello,
We have a very difficult connection problem with our electronics.
We need to connect from a 4 Amp current source to a bank of LEDs (46V across the LED bank which comprises parallel LEDs ) in a big light. The LEDs are mounted on MCPCB and thus it is difficult to solder big connectors to the MCPCB. The MCPCB is very small and the LEDs are mounted next to each other to assure good thermal coupling. It is also a slightly moveable light, and so we need the cables (wires) to be malleable and thin. Therefore, we are paralleling multiple 26AWG wires, -however, it is not a good solution, and we are not derating the connector senough (Molex picoblade 1.25mm pitch)
Supposing we contact an interconnection company such as Contour.uk.com
http://www.contour.uk.com/
They will be better qualified than us to specify a suitable cable assembly with suitable connectors, but what will they ask for in terms of money? I mean, once they’ve told us which cable and connector to use, what’s to stop us from just using it and not paying them anything? So I guess I am asking, “how do companies like contour.uk.com make money?
(We don’t want to ask contour this question as its not an “appropriate” question to ask a company)
