milan.rajik
Banned
- Joined
- Apr 1, 2013
- Messages
- 2,524
- Helped
- 540
- Reputation
- 1,078
- Reaction score
- 524
- Trophy points
- 1,393
- Activity points
- 0
I want to control a 440V 3 phase 30A pump using a relay. Which Industrial grade relays can I use ? Is it better to use 3 Pole electromagnetic relays or should I use Crydome Solid State Relays ? If Solid State relays are used I thing the cost will be more and I also have to use a heat sink with a cooling fan and a temperature sensor to sense the relay temperature and control the cooling fan using PWM.
Cost is not important to me. I can use either Crydom or Schnieder SSRs. They system is a GSM based PUMP control for farmers. The pumps are turned ON/OFF two times a day atmost. At some places the farmers have to walk 1 km to turn ON/OFF the pumps. I want to know if there is a Single SSR which controls the 3 phases. My pump rating is 440V 3 phase. I am thinking about using SOLICON DRC Series series of Crydom relays which is rated for 510VAC 30A. Do I need any special means to drive the SSRs ? If there is an Single SSR which can control 3 phases then I will make a system which have option to control 8 pumps.
