What kind of value is received in microcontroller while interfaced with IR receiver?
Pari Boopathy
Newbie level 6
Newbie level 6
i am connecting the IR receiver to PA.0 of microcontroller(ARM CORTEX M4).i m in need to know what kind of value is received in PA.0....Whether it receives the binary values or else in Pulse form...IR Receiver-HS0038...:?:
The data sheet will tell you.
It is both, there isn't much else you could expect from a single pin input. The actual pulses are the same as the envelope of pulses sent from the IR transmitter but with the carrier frequency removed.
Brian.
Brian.
Thank u Brian..
I am using TM4C123GH6PM Microcontroller.I dont know whether the Single Pin receives a 1 byte value or more than that??The pulse which consist of [Start bit(1 bit),Address bit(16 bit),Command bit(16 bit)]..Single pin is enough to capture all r not??
if not how can i interface??
Google for RC5 protocol, respectively other protocols of interest.
I am using NEC protocol...My doubt is in microcontroller and programming part only..How microcontroller receives data from Ir receiver?Each pin in microcontroller receives one bit only...
I m going to connect my IR receiver to PA.0,then by using Timer and interrupts, i receive Single bit values every time and store in variables...I don't know whether my concept is okay or not?
Thank u Brian..
As Brian said, it depends on what the transmitter is sending. Maybe this figure will help you understand. The top part is what the IR transmitter sends; the bottom is the signal from your receiver to the MUCU.
John
Yes. SIRC reception depends on detecting pulse widths. You'll count bits and shift the bit value into a register.
