What kind of analysis can be done with SPEF?
au_sun
Full Member level 2
analysis with SPEF
u can use it for Timing anaylsis & cross talk anlysis
DAWEN
Re: analysis with SPEF
and how to do that?
can I use hspice to simulate my design using the .spef file?
vlsichipdesigner
Full Member level 2
India
hi designer,
my 2 cents,
1. You read the routed netlist and the SPEF file in the primetime and perform post-routed timing analysis.
2. You read the routed netlist and the SPEF file and generate SDF[Standard Delay format] file. Use the routed netlist and SDF file for gate level simulation to check whether you are meeting functionality & timing.
Praise the Lord.
best regards,
vlsichipdesigner
https://www.vlsichipdesign.com
chip design made eazy
