What is XSPICE and how is it different from Orcad or Pspice?
kamalakhavan
Newbie level 1
Xspice
hello
What is XSPICE and what's different between it and orcad or Pspice?
Re: Xspice
Xspice is based on the original Berkely spice (it can do everything the original spice can) but includes the ability to incorporte arbitrary user models. I think it originated at Georgia Tech so you can probably find more info there.
A lot of the newer EDA spice packages are based on xspice. Pspice also has extensions to the original Berkely spice, and afaik uses no legacy code. Pspice is as good as anything for low frequency work - otherwise look at HSPICE.
Re: Xspice
Xspice is fast but Hspice is more good...i don't have trust in Xspice. i simulte same circuit with Xspice and Hspice and the results are different. try it both and you will se the difference .
Re: Xspice
Hi, Sergiu_Q
Can you describe the differnece?
Do you use equivalent models?
regards
dora
Re: Xspice
i dont know how good is xspice, but, i know that Hspice is the tool in simulation iof IC by the industrie.
Re: Xspice
Try Hspice and SmartSpice. Both are good. First is more accury, the latter is faster.
Re: Xspice
Hspice is better than Xspice .
HSPICE® is an integral component of Synopsys’ comprehensive mixed-signal verification solution, Discovery AMS. HSPICE offers
a high-accuracy circuit simulation environment that combines the most accurate and validated integrated circuit (IC) device models
with advanced simulation and analysis algorithms. As IC geometries continue to shrink, the need for an accurate circuit simulator is
critical. Designers require a highly accurate circuit simulator to precisely predict the timing, power consumption, and functionality
of their designs. HSPICE provides the industry’s most trusted and comprehensive circuit simulator engine and device models.
HSPICE’s simulator engine has been successfully used to design over one-million integrated circuits. Its advanced circuit simulation
algorithms provide HSPICE with convergence characteristics that are superior to other tools.
Benefits
■ Provides golden accuracy for circuit
simulation
■ Supports the most accurate and
extensive set of industry-standard and
proprietary simulation models
■ Supports scattering-parameter
(S-parameter) modeling during
transient simulations
■ Eases adoption through extensive
foundry support and comprehensive
support for industry-standard formats
■ Supports comprehensive interconnect
and signal-integrity analysis solutions
■ Supports extensive cell-characterization
capabilities
■ Supports extensive optimization and
corner-case analysis capabilities
Accurate device modeling
An integral component of circuit simulation
accuracy is device modeling. HSPICE’s
international team of device-modeling
scientists ensures that it has the most
up-to-date and accurate set of industry
standard model implementations. The
comprehensive set of HSPICE models have
been extensively proven in CMOS, bipolar,
BiCMOS, Silicon Germanium (SiGe), SOI,
Gallium Arsenide (GaAs), and Indium
Phosphide (InP) technologies.
In addition
to all basic SPICE models, a partial list of
advanced models for HSPICE includes:
■ MOSFETs: All revisions of BSIM3,
BSIM4, Philips MOS9/11, EKV, and
HiSIM.
■ Bipolar transistors: All revisions of
VBIC-95/99, MEXTRAM, HiCUM,
MODELLA, and UCSD-HBT.
■ Field effect transistors: Materka,
Curtice, Statz, and TriQuint TOM1/2/3.
■ Silicon on Insulator (SOI): BSIM SOI 3.1
PD/FD/DD, UF-SOI, and SOSFET.
■ Thin film transistors: All revisions of RPITFT
and HP amorphous-Si.
■ Special devices: Junction varactors,
silicon MOS interface, IC resistors,
and capacitors.
Re: Xspice
Daneshgar, you look like a sales man from synopys.
However, Hspice is the most used analog simulator in industry. This tells everthing ....
Bastos
Xspice
