-- Company:
-- Engineer:
-- Create Date: 14:48:40 09/27/2018
-- Design Name:
-- Module Name: Mux256 - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
--use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.NUMERIC_STD.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity Mux256 is
Port ( inp : in STD_LOGIC_VECTOR (255 downto 0);
sel : in STD_LOGIC_VECTOR (7 downto 0);
outp : out STD_LOGIC);
end Mux256;
architecture Behavioral of Mux256 is
signal sig_sel: integer;
signal sig_sel1: unsigned (7 downto 0);
begin
sig_sel1 <= unsigned(sel);
sig_sel <= CONV_INTEGER(sig_sel1);
process(inp, sel)
begin
outp <= inp(sig_sel);
end process;
end Behavioral;
and here is its test bench, The code is synthesizing but when i run the simulation, the index is showing the negative value and simulation wont start
library IEEE;
--library UNISIM;
entity Demux256 is
Port ( inp : in STD_LOGIC;
outp : out STD_LOGIC_VECTOR (255 downto 0));
end Demux256;
architecture Behavioral of Demux256 is
signal temp_out: std_logic_vector (255 downto 0);
begin
process(inp, sel)
begin
if(inp = '1') then
temp_out(sig_sel) <= '1';
else
temp_out <= (others => '0');
end if;
end process;
outp <= temp_out;
end Behavioral;
Re: What is wrong with this Mux code using indexing
What do you mean by "wont start"
You have a library conflict. Both std_logic_arith and numeric_std declare the unsigned type, meaning neither is visible. std_logic_arith is not a VHDL standard library, so you should comment it out and use only numeric_std.
sensitivity list has sel, but process uses sig_sel.
you can use numeric_std with the double-conversion method -- to_integer(unsigned(x)). You can also import only conv_integer from std_logic_arith, but people will yell at you.
There may also be unconnected signals. You attached your array of latches "demux" instead of the testbench. Also, the implied circuit seems really unreliable.
ISE10.1 probably has no support for VHDL 2008, they hardly have any support for it in ISE 14.7.
Xilinx tool support has traditionally trailed the standards by at least 5-10 years. Just checked, ISE 10.1 was introduced in 2008, so it probably has no VHDL 2008 support and if it even exists it's alpha code and I wouldn't trust it to work correctly.
When I tried to run the code in Vivado, the output of sig_sel <= TO_INTEGER(unsigned (sel)); ========= -2147483648 which cannot be an index value as I want sig_sel to be the index of inp(sig_sel)
Please help me out
