[SOLVED] what is "w_windowId"
egx
Junior Member level 2
i am trying to learn skill scripting nowadays and i am very new.
for some functions i need value of w_windowId.
i dont know what is it. its described as "Object ID of the window containing the cellview"
how can i learn that id?
thanks
"w_windowId" -- by default -- is the current window. To display the database object ID, in the CIW type:
getWindowCellView(w_windowId) or:
getWindowCellView()
s. e.g. cādence' Custom Layout SKILL Functions Reference, p. 468 (Product Version 5.1.41, Nov. 2004)
getWindowCellView() doesnt work. it says undefined function.
here smo had the same problem.
https://www.edaboard.com/threads/104499/
but no answers. if you could give examples that would be easy to understand.
WHat version of cadence you use? They changed quite a bit of skill in 615 and some of it is not correctly documented...
and also try using: geGetWindowCellView()
thanks for your attention.
what i was searching is the code:
hiGetCurrentWindow()
