What is USB port maximum current ??
hameeds01
Advanced Member level 2
Islamabad Pakistan
USB port current ??
how much maximum current that i can draw from the USB port of my labtop??
what gonna happen if in case i short the USB supply lines 5Volts ????
does it has any protection circuit in it to protect the laptop??
Jack// ani
Advanced Member level 3
USB port current ??
Maximum current you can drain vary from 100mA-500mA(max) and it is overcurrent protected.
My desktop machine use to reboot if I drain too much current, although I never actually measured it!
nandhu015
Advanced Member level 5
India
Re: USB port current ??
hi
My laptop powersdown usb device and give me a warning that usb device is consuming high current
Nandhu
xuan1982
Newbie level 3
Shenzhen,GuangDong,China
laptop usually support 5V. mainborad usaually has protection circuit.
but i don't suggest you do it.:D
pranam77
INDIA
USB port current ??
New versions of mother boards have a poly fuse in series to protect the USB port from over loading. In case a load is connected above the set limit, a popout window on the screen warns the user about the same. But do always do experiments at your own risks. Cheers
elrayes
Full Member level 5
Egypt/Canada
USB port current ??
usually for USB 2.0 initially supplies 100 mA without request, if you need more current the USB device must request this from the hub in terms of units, each unit 100 mA till you get the maximum which is 500 mA.
Jack// ani
Nice to know that.
It very well explains are my old desktop use to reboot instead of giving over current drain warning as mentioned by nandhu015.
