[SOLVED] what is this warning message
Serwan Bamerni
Member level 2
Member level 2
dear edaboard member
when i am trying to synthesis a VHDL code in ISE 14.1, i get this warning message
WARNING:Xst - The specified part-type was not generated at build time. XST is loading the full part-type and will therefore consume more CPU and memory.
it is my first time i facing such warning
what does it mean?
and what is the wrong and how i can overcome this warning message
I think it means you didn't specify the entire part you are using for XST, which likely stems from not specifying the full part number in the project->design properties->[family][device][package][speed] select boxes.
Perfect, you are right. I don't know how i miss to full this information
Thank You
