abaz
Member level 2
- Joined
- Apr 26, 2011
- Messages
- 51
- Helped
- 7
- Reputation
- 14
- Reaction score
- 7
- Trophy points
- 1,288
- Location
- Berkeley, Australia
- Activity points
- 1,609
You will probably find that the diesel was fairly well loaded so that fluctuations in the alternator's load were redily apparent in the diesel's operation.I don't know what the "prime" generator set up does but I have worked on Diesel generators of about 500KVA ratings and the main problem we had with them was that the speed governor hunted,... Frank
Most decent AVR's have a sensitivity or speed adjustment that determins how quickly it should respond to changes in electrical load. If it's set to high then it will respond to its own changes causing "hunting" in either the electrical load, or in the case of a diesel nearing it maximum output, rpm
