I cannot figure out what does this mean...munzir said:what is the working of AVR in a Generator ?
Home portable generator is a device. Prime generator is an algorithm. What differences are you referring to?munzir said:Difference between home portable generator & prime generator ?
You probably mean the Automatic Voltage Regulator, though AVR can mean other things in electronics, such as the AVR family of microcontrollers. The AVR in a generator does exactly what its name implies: It regulates the voltage output.what is the working of AVR in a Generator ?
I'm assuming that by prime generator you mean one of those big ones used by a public power supply agency. Apart from size and power capacity, the differences can be major or minor depending on particular models. Some simple portables are nothing more than a powerful magnet rotating inside a coil. The AC voltage and frequency are controlled only by the engine speed. Others have a basic AVR and still others are quite sophisticated. All but the simplest ones have some kind of feedback that monitors the output and adjusts it by varying the current in the field coil.Difference between home portable generator & prime generator ?
what are the electronics & electrical parts present in a home portable generator ?
To both questions: All the usual active and passive electronic components - ICs, transistors, diodes, resistors, capacitors, thyristors, etc.Of what parts an AVR is build up ?
If there are some fairly complex electronic circuits somewhere on the generator (not just rectifiers), they are most probably the AVR circuits. An AVR is also likely to have at least one adjustable component for adjusting the output voltage.how can i get to know that this generator whether industrial or home portable has AVR in it ?
There is no standard location for the AVR. You'll just have to look and see for yourself. Some large industrial generators may even have the AVR in a separate box that's not attached to the generator body.Generally, where it is connected or present inside the generator ?
