T
treez
Hello,
Regarding offline, domestic , SMPS's of about 15-30W power, what is the usual reason for them to fail?
Also, can they be repaired?
Is the main failure mechanism the occasional 1KV line transients that eventually blow out the MOV, and then blow out the circuitry that was protected by the MOV?
Or is the main failure mechanism the drying out of the electrolytic capacitors, which overheat due to their increased ESR when they're dried out?.
I am just wondering, if the problem is overheating, then it may be an idea to put in a temperature monitor and shut the thing down when it overheats, then it can be repaired by replacing the electrolytics, and then sent back into service?
